It`s very simple-- above lic. plate you will see the light lens. There may be 2 phillips screws, if there are just remove them and use a small flat head scewredriver to pop it open. Then remove the ``penut`` bulb. If there are no phillip screws, then use the flat head to pop the lens.
Also before you start lift the trunk open and see if you can access the bulbs from in there.
Good luck-it is very simple..
