I just bought a 2007 kia sedona and it pulls to left at low speeds i brought it back for them to do an alignment and it is still pulling to the left after they aligned it. What can i do to get this problem fixed?
Re: I just bought a 2007 kia sedona and it pulls to left...
Are --Motor & Transaxle Mounts good?
Are --drive axles okey?
Tires at same pressure,same diameter,
when aligned?
Did they check for ride height & bent components?
I was thinking there was little chance for a crossover
b"twix these KIA spheres of power influence... but staring
at the drawings I keep seeing "clock-spring"...
but since "clock-spring" usually means steering wheel
remote controls you might want to FORGET about blower
RESISTORS and focus on the blower speed controls.. and "REMOTE" controls there-from...
Any chance your HVAC has provisions for the STEERING WHEEL...?
You asked for "ANY" thoughts...
That's "justa" thought.
The other way to find a CROSSOVER would be to pull the 7.5 Amp fuse... Put on a TONE-TRACER and start OPENNING
the HVAV circuits until you find the lighting tone...
NOTE: Toners do not work on closed systems
(pulling the LIGHT fuse... with the "interior" lites off
should be the END of your tone search...
If the tone goes further... WIRES are crossed
(find by pulling fuses & connectors OPEN.
hey i have a sedona 07 and it just hapen to my i dont know if theres a esear way of doin it but i pull the hea light out you ondue 2 screws on top of the light pulls out make sure you dont touch the new bulb( the glass) also you only find it at the dealer chip its only 18 dollars,.
Remove the headlight assembly. Just remove the 3 bolts with a 10 mm socket and pull it out so you can disconect the wire harness. After that pull the whole assembly out and unscrew the bulb cover. The bulb is held in with a spring clip.
