1.Reset router back to default settings,reset button on router.
2.Then use default key on the back of the router to configure.
3.Once you're in just change to the your preferred password.
an apple airport extreme , a netgear wireless g router or Pre N or a linksys G wireless router or Pre N router ( depending on how much you have to spend )
Also draytek are very good but pricey ( maybe check ebay for a draytek )
what is happening is that ur router of modem is assigning the same ip´s to ur PC´s
call the original manufacure of that device and they will have ur modem or router to asssign diffren ip´s to ur pc
that should do the trick
i would need more info to walk you through that would be better on the phone so give that a try
but that´s what is happening
rate me please
f you have forgotten the password, you can reset the WiFlyer to use factory defaults for all settings using
the following procedure.
1. Disconnect the power cable from the back of the unit.2. Press and hold down the "quick connect" button.3. Re-apply power while continuing to hold down the button.4. Release the reset button once all 5 lights have come on and the unit has beeped 3 times.5. If unit does not beep (volume off), wait for the lights to start
coming on a second time before releasing the quick connect button (about 12 seconds).Note: Resetting to factory defaults will remove any custom configuration,
including access numbers, that you have entered and you will need to configure
the base station again.
The signal indicator only tells you that you are connected to the router. You need to make sure that your router is connecting to the internet. go to it's configuration page by browsing to http://192.168.0.1 (note that this address is correct for many routers but not all, check the manual to be sure) find the tests or diagnostic section and run the connection test.
That would require knowing the manufacturer and model of the wireless printer, please. AND confirming the wireless router model is the one indicated on the page
