I HAVE PROBLEM THAT MICROCODE UPDATE ERROR NEW PROCESSOR STEPPING MY MOTHER BOARD HP D530 SFF(DC578AV) AND MY Processor x86 Family 15 Model 4 Stepping 1 GenuineIntel ~2793 Mhz
Re: I HAVE PROBLEM THAT MICROCODE UPDATE ERROR NEW...
Did you change the processor?
Did you get this error-message before you changed the processor?
Have you done any BIOS-updates (by downloading an updater from http://support.hp.com ) ?
Hi, To remove this error, you have to download and install the following HP COMPAQ D530 SFF Microcode Update Download the update from the above link. Read / follow the instructions carefully. This package contains a utility that can be used to install or upgrade
the processor microcode on the listed HP Compaq Business Desktop D530. Hope it helps! Good Luck! CreativeTECH
Hi, To remove this error, you have to download and install the following HP COMPAQ D7100 SFF Microcode Update Download the update from the above link. Read / follow the instructions carefully. This package contains a utility that can be used to install or upgrade
the processor microcode on the listed HP Compaq Business Desktop D7100. Hope it helps! Good Luck! CreativeTECH
OK I FIXED IT BY UPDATING THE BIOS VERSION OF THE MOTHERBOARD..IT HAPPENS WHEN YOU HAVE REMOVED THE PROCESSOR OR YOU HAVE REPLACE GOR ANOTHER THAT IN TEORY IS COMPATIBLE WITH YOUR COMPUTER...THERE IS AN UPDATE BIOS IT WILL FIX YOUR PROBLEM..IN THIS CASE YOU DONT NEED TO USE THE CLASIC FLOPPY BOOT DISC JUST DOWNLOAD IT TO YOUR HARD DRIVE AN RUN IT LET BY ITSEL TO DO THE JOB AND YOU DONT HAVE TO WORRY AGAIN TO PRESS F2 TO SKIP THIS MESSAGE ERROR IN YOUR WINDOWS BOOT INTERFACE.. YOU CAN GET THE UPDATE OF YOUR COMPUTER AT
WWW.HP.COM
MAKE SURE YOU PUT ALL YOUR MODEL AND LINE PRODUCT EG:COMPAQ PRESARIO SR140WM BIOS UPDATE THATS THE ONE I FEX WITH AN BIOS UPDATE IT WORKED FOR ME I HOPE IT WORK FOR YOU ALSO ...IF NOT JUST LETME KNOW.....BE CAREFULL WITH THE BIOS UPDATE YOU CHOOSE IT MUST BE THE CORRECT OR YOU WILL KILL YOUR MOTHERBOARD...IT MUST BE FOR YOUR COMPUTER MODEL IN CASE OF YOU DONT FEEL SO SECURE I CAN GIVE SUPPORT THRU FIXYA JUST LET ME KNOW YOUR LINE AND MODEL THERE YOU HAVE A FULLLINK TO DIFERENT WINDOWS VERSION MICROCODE UPDATED CHOOSE THE ONE FOR YOU...http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=es&cc=es&prodNameId=316715&taskId=135&prodTypeId=12454&prodSeriesId=316713&lang=es&cc=es GOOD LOOK WHIT THIS BIOS UPDATE YOU DONT HAVE TO WORRY FOR *********** BOARD...I ALREADY MADE THE RESEARCH..GOD BLESS YOU DONT FORGET TO LAEVA A COMMENT AND A VOTE FOR ME..
I have installed d530 sff mother board & processor is 3.0GHZ 800mhz error is showing. Microcode update Error. Missing or Invalid processor microcode update. Please contact HP company.
Goto http://www.hp.com/#Support > download drivers and software > enter pc model number and search select the os you will find BIOS Family Processor Microcode Update click on that link ; you will find the installation instruction and download file
