My gateway T-1628 notebook's fan will get really loud all of a sudden even if it's not hot. It will then shut down without any notice.
I had same problem with a HP Pavillion ZD-7000.
Turned out to be dust had accumulated on the cpu making it run hot. Get a can of the dust off high pressure air and blow it into the fan intakes and output vents. Cleared my problem right up.
This Could be a System Processer failure...
Try to Remove everything from the PC, Including Battery or Power surge f you have connected in between te Power socket & PC.
then Try to turn it on.
If the Problem Exists then the comp needs Serviced at the service center.
