It's swing or vent motor sound. After you switch off it takes 5 second to close vent by vent motor.
Please lift the front cover and check your indoor coil is ice formed. When you switch off the ice started melting and sound like you mean. Please check next time when you switch off. And also state about cooling effect. Thanks.
ac is switched off since last week, noise occurs usually from noon - 3( even though ac is not turned on from days) . seems like ac lineset is in contact with wall , something to do with outside temperature
Did you remove your plug from power? After removing plug, if sound inside the blower means May be rat or squirrel would have entered inside the blower unit, I think.
it is kind of banging sound, on the adjacent solid brick wall of ac, that wall has no water pipe, neither bathroom is nearby.the nearest thing is ac
it is kind of banging sound, on the adjacent wall of ac, that wall has no water pipe, neither bathroom is nearby.the nearest thing is ac
