Cell Phones Logo
A
Anonymous Posted on Jan 09, 2011
Pls help me,,before,when am calling or receiving,the network will disappear,later it will come back....i now angrily smash it on the floor,since then it has been writing sim card rejected......
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Jan 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
1496
Points
30
If the network was unavailable it may have been a problem with your network provider you may have been in an area with low connectivity and as for the "Sim card rejected" when you smashed bits and pieces may have came loose in your phone you might need to change your service provider and get a new phone.
1helpful
I use a H760 wireless headset of Logicool. Today, the wireless receiver usb showed only blinking green light. For 5 minutes later, the green light was disappeared. The headset didn't work. Can I...
Yes, it normally works for me to put the usb into a different usb slot. This will reinstall the driver for a different usb slot and make it work perfectly!! Make sure it is charged, and that you have powered it off and back on first.
6helpful
3answers
My mobile phone received an Orange message saying 'Update error 020146'. All Inbox messages disappeared! What is the cause?
Hi, I have had the same problem, its to do with the merging of Orange and T-Mobile networks to give you better signal coverage, but if you have an old phone or sim card, mine is over 12 years old, it wont automatically update, hence the error message. You need to call 150 from your mobile and ask them to send you a new sim card, which you will need to register when you receive it. Good luck, PS Dont bother going into the shop, they couldnt help me, although you could call from there.
I recorded 'Rocky' on the DVR at 4/16/10. Once I saw it on the recorded movie list, I made sure to protect it, and it was fine until today, when it just suddenly disappeared. The event list is currently...
Hi, my name is Phillip Chang and I work with DISH Network's Technical Support Team.
We are sorry to hear that Rocky was not recorded like you had wanted it to be. If this were to ever happen again unplug the receiver for 10 seconds then plug it back in.
If the issue continues after this give us a call at out 24/7 technical support number for additional steps:
1-800-333-DISH (3474)
4helpful
My Xda Zinc displays no network service all the time. I already tried changing sims but none of them has network signal. i tried the soft and hard resets but still doesnt work. I cannot call, txt and even...
My Xda Zinc displays no network service all the time. I already tried changing sims but none of them has network signal. i tried the soft and hard resets but still doesnt work. I cannot call, txt and even received messages. need your advise. pls. help.
2helpful
E71 Pro Mobile TV not connecting to mobile networks
my tv mobile and dual sim E71 made by CHINA not sported any software please tel me sported software and type of sported software.THANKS
Sep 07, 2009 • Cell Phones
2helpful
2answers
Nokia mobile fone not working
i have a nokia 5500 sport model. it has somehow started to act funny ... while using, suddenly its network/signal disappears and never comes back.
T5950 2-way
Initially, pls check that the displays of both radios are identical. This is important to establish that the channel/frequency, Interference eliminator settings and all others are the same that both are paired. In some instances, the radio settings may not be changed if it is locked. Top unlock, press on the MENU button for about 3 seconds. For all other settings, pls refer to the user's manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Closed captioning disappeared
Within an hour after I posted this request (6/28/08), I solved the mystery by unplugging the receiver, waited one minute and re-plugged it back in. Closed captioning is back on again.
2answers
Network disappearing
try changin the network search to manual and manually select the network you are on right now..
if 3G network is availavle, do not choose that.. choose any 2G or 2.5G network for your service provider that wud be available..
if that doesnt work, try to delete all the cookies and stuff from the phone, delete all network settings you got on ur handset, and ask your service provider for the settings again..
1helpful
No singal
You might think m joking but m not.............wrestle again or through your phone on floor not from height make sure u dont break it.I did the same take out your battery put it back turrn your phone on again i should show you signals,if you still dont get it then go to settings>>connectivity>>network selection>>manual and select your network. it will take some time(maX 2 mins) to select your network....n your phone is back to working order.[i tell you again dont smash it on floor it might break it or you can through it even on a matress]
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
