Here are the procedures.
WATER PUMP
Removal
1. Drain cooling system. Remove timing belt. Remove right ignition coil. Disconnect coolant hose from coolant inlet housing.
2. Remove retaining bolts and separate coolant inlet housing and "O" ring from water pump. Remove retaining bolts/nuts and water pump. Remove "O" ring from coolant by-pass pipe which fits into rear of water pump.
Installation
Ensure sealing surfaces are clean. Install NEW "O" ring on coolant by-pass pipe. Lubricate "O" ring with soapy water solution.
2. Apply a .08-.12" (2.0-3.0 mm) diameter bead of sealant on mounting surface at rear of water pump. Install water pump. Ensuring water pump engages over coolant by-pass pipe. Tighten
fasteners to specification.
See
3. To install remaining components, reverse removal procedure. Fill and bleed cooling system.
For water pump replacement i suggest you to check the help link
provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile ?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Car ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located ?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
This will help. Thanks.
provided below.
provided below.
provided below.
provided below.
provided below.
provided below.
provided below.
provided below.
How to route Water Pump Belt?
