Hi, Have you tried plugging in what you have unplugged? Try turning it on with the case open and see what is going on. You may need to take out the bios battery out and then turn it on, then turn it off and re plug in the bios battery. How long did it work after having the usb port in the front broke?
Once I have more information I can assist you further.
Thank you,
Lee
You plugged it in and unplugged it? Leave it plugged in and see what happens. It sounds like either a failing motherboard or something else. I need more detailed information to be able to properly assist you. Also what do you mean by when you turned it on it worked for a couple of hours.
Thanks,
Lee
I replugged the plug that goes to the frontal panel it and unplugged it. Still didnt work. And when opening the case I heard it start booting up and then I heard the fan go quiet. I saw a yellow steady light on the motherboard. What is the Bios Battey? And when I turned it on it worked for a cuple of hours.
