You may have a bad motor. For more technical info go to 'SEARS PARTS' inter the model,inter the error code. Disconnect the AC power before removing any screws!!!!!
if you are sure it is the right code, leave radio on for one hour then re-inter code. if you intered an improper code, after a few tries, it could be locked up.
Nokia restriction codes are used to unlock the Nokia phones locked to
any particular network in the world. You can get the sim unlock code
from the current service provider or from the online unlocking sites. i
will suggest the website MobileUnlockSolutions.com which is doing good
service .....you can approach this websitet
i have sulation if u hhave bios programer i have bios this model if u no have u 3 time inter inter inter system give the code plz send me coad i give u master password
thanks
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
Basicly there is not a trick to the S.P. mode. You go in to it & touch The S.P. on the display and then turn the main power switch off and then back on and that is that is needed. But if that did not work you will need to go deeper in to the problem.
