Activision Cabela's Dangerous Hunts 2011 with gun for Xbox 360 Logo
A
Anonymous Posted on Jan 03, 2011
Cannot connect rifle controller to my Xbox 360. It a special edition unit so I dont know if that makes a difference. Instruction say press connect on the console itself but my xbox is completely wireless and no connect button on console
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Jan 12, 2009
SOURCE: Multiplayer mode Kung Fu Panda pc game
The xbox 360 wirless controller has very little lag that you would not be able to notice i would suggest just getting the controller and if u want u can also get a xbox 360 controller that is wired.
Anonymous
  • 152 Answers
  • Posted on Apr 06, 2009
SOURCE: Syncing problem? Xbox 360
Is your TV a HD TV? Be sure to go to options and synchronize the game. There are delays with HD TV's and the GH/Rock Band games.
Also, try using a wired guitar to see if there is a problem with the wireless guitar you are using.
Hope this helps!
Espen
  • 15 Answers
  • Posted on Apr 13, 2009
SOURCE: Guitar not working for Xbox Guitar Hero
This got to be a hardware failure with the guitar, there is no wires or some button you pressed by mistake.
Try checking out that cables are plugged in, try to switch USB port to connect on the xbox 360, or else its a hardware problem.
Espen
  • 15 Answers
  • Posted on Apr 17, 2009
SOURCE: cant sync drum kit
after the 4 green lights are flashing you sould just wait for 10 sec and then it shall be connected.
Unless, try to change batteries on the drum kit, and then try again.
arcavazos837
Alberto Cavazos
  • 112 Answers
  • Posted on Dec 30, 2010
SOURCE: the board doesn't connect to the Xbox360. the
Usually xbox 360 accessories connect without a usb connector. They sync with the console like a regular controller would.
Please Rate.
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
3 days ago i took my 1st player xbox 360 controller to my cousins' home and connected it with their xbox 360 (same model) toplay games with them. yesterday, when i came back home i tried connecting my...
Here are the things you can do to solve the problem.
1. On the front of the controller and the system there is a little button you can press that can connect to each other for you to play.
2. Make sure that the batteries are properly placed inside the battery pack under the controller.
3. Make sure the batteries are not dead.
I know this is not much but I hope this information helps you.
2helpful
Xbox 360 controlle not working
Have you tried pressing the sync switches on both devices, its the little white button on the top of the controller and the one on the 360 is near the memory card b slot (round white one) press the one on the controller and the lights shoudl start flashing then press the one on the 360 while the lights are still flashing they should then flash on one light about 3 times to indicate success. if this doesnt work you may have a faulty RF(radio frequency) unit, this is the wireless device which communicates with the controllers, if this is the case you can get this replaced at your local pc shop for around £20 to £30.
Hope this helps
Paul
2answers
How to setup two wireless controlers to an xbox
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
  6. Note If you want help connecting an Xbox 360 Wireless Controller to your Xbox 360 console, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
  • The controller remains connected to the Xbox console even when you turn off the Xbox console.
  • The controller is connected to only one Xbox console at a time. You can connect the controller to a different Xbox console at any time, but your connection to the previously connected console is lost. You must repeat these steps to reconnect the controller to the original console after your connection to the console is lost.
  • The controller works within 33 feet (10 meters) of your Xbox 360 console. However, objects between the controller and the console may reduce this range.
  • If the controller does not turn on, the batteries may have to be replaced.
Help me please!!!! how many different types of xbox 360s are there in gamestop tell me there names and prices. and is it okay to get the xbox 360 pro refurbished at gamestop are the refurbished xbox 360...
personally never buy a refurbished xbox,unless u want to be swaping parts in and out all the time, people dont usually return xboxs, simply becasue of the multimedia se unless it has gone bad, so spend that extra money and you should be set there is the xbox elite, in black and xbox pro in plain white but there is different versions like 60 gb 8 gb or 40 gb harddrives. there is also special edition xboxs but gamestop might not carry them
2answers
Xbox 360 will not search for wireless controllers when search button is pressed
For pairing the Xbox 360 controller make sure you hit the pairing button on the wireless controller and Xbox 360 unit together, there's a little circular button under the memory card 2 slot, press it (while xbox is on)
now press the one on the controller (next to lb) and it should connect.
here's a diagram representation of pairing process for further help
Hope this helps, Please do take time to rate my solution
Wishing you Happy Holidays and Happy Gaming
Regards
KreativeGeek
http://gamingbox.wordpress.com
http://www.kreativegeek.com
What happens if you press the sync button on the vbox 360 controller and the LED button lights upbut cannot get connection to the xbox 360
There could be a problem with the Controller or the RF unit on the xbox 360 console. Try another controller to make sure its not the RF receiver inside the Xbox 360. Usually when you press the Sync button on either the Xbox or the controller the lights on the X circle should spin and then flash on number 1 and stay a steady green on both the console and the controller
Microphone doesn't register voice
The headsets that come with the xbox 360 tend to break somewhere inside of the controller connection point.
Try moving the wire around ( by the controller ) while talking and see if it works when you hit a certain position.
If it does start to work, you can try fixing it -or invest in a headset from a different company.
Top Activision Video Game Consoles & Games Experts
Sean Wright
Sean Wright
MegaByteMe
MegaByteMe
john h
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
