If your phone keeps freezing up on you, then it means there are too many files and folders on it, try to delete some of the files you are having on the phone to relieve it of too much load, and be sure not to have too many applications that are large on the phone. Watch the size of our memory card and the space left, because the phone will be finding it difficult to load large files.
I will advice you reset the phone if it does the same, even after offloading some files from it. To reset the phone, go to the main menu of the phone, select the settings, scroll to security ans select it, then you select reset from the settings, it will prompt for a security code, enter the phones security code and it will reset the phone for you, that way your phone will be in good condition and work properly without freezing.
Take care and good luck
Warning : Do not enter
any wrong unlock codes on your LG GR500 Xenon mobile phones. If you
enter over a certain amount of wrong unlock codes on your LG GR500 Xenon
mobile phone, your phone may get hard locked and sometimes become
unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
