Uscamera.com sells the latch for $6.50 and $3.50 U.S. mail postage. I got one to replace my broken latch, but can't yet understand how to get latch and its spring installed.
JustAnswerhttps://www.justanswer.com > Electronics Question
Mar 5, 2020 - Your old camera model DX7630 only supports SD memory card type, which has size of 2GB or less. Your camera does not support SDHC card type ( ... 1 answer · Top answer: Hi, I'm sorry about your camera issue. I'm glad to assist you today. Did you purchase new ...
ZDNethttps://www.zdnet.com > product > kodak-easyshare-d...
The camera includes an SD memory card slot located next to the battery compartment. The purchase of a 128MB or greater SD memory card when you buy the camera is ...
Pros and cons: Picture quality is excellent ? Battery life is excellent ? Easy to use menus ? View full list
I had the same problem and was able to find a replacement lock and spring on e-bay from US Camera - P/N 370388337496). They may have none left. Not sure.
I have no instructions on how to install the replacement, but don't think it should be that hard (haven't installed mine yet). It is called a Kodak DX7630 Battery Latch and Spring Assembly.
You can also contact United Camera Customer Service (1-630-595-2525) and talk with them. They are the company that Kodak will send you to for repairs to your DX7630.
The part number From Kodak PartsDepartment (1-800-431-7278 (opt #2) is: F6170 for the latch. The did not have any springs on hand.
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
IMy battery lock is broken where I can find replacement?
