Italian to Eng
Hi everyone I have a problem with the mobo asrock p4vt8 + when the boot gives me this screen: scan devices please wait ... press <tab> key into user window! serial_ch0 master: no device serial_ch1 master: no device cmos settings wrong press f2 to run setup press f1 to load default values and continue but when I press f1 or f2 the computer freezes, I want to make it recognize the hd ide but I don't know how to do it ! thanks in advance
the coin cell battery is dead
or the hdd is dead
there are 2 cures.
1: new battery and reset bios.
2: test the hDD if bad , it must be replaced and new OS installed.
SOURCE: I did BIOS flash update on my ASUS P5WD2 Premium
Install the BIOS Flash update, one by one. Like for example 1.0, 2.0 or 3.0.
And if still the problem consist. I think its not your BIOS problem.
Clear the BIOS by disable the JUMPER Setting.
And one last thing change the LITHIUM BATTERY(CR2032) a new one.
If you got the problem again, put a comment so that we can easy understand what is the problem with your MB.
If i am helpful, please rate me.
Thank you very much.
Yboyandrei
SOURCE: when plug on the ups then after post operation a
You have to replace the battery in your motherboard. You will get it in any computer or electrical shop.
SOURCE: mi servono tutti i driver
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
SOURCE: Hi, I really need your help, please help me. I get
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/r/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
