Nikon Speedlight SB-22S TTL Flash Logo
Posted on Dec 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flash Nikon SB-22S works with nikon d60? - Nikon Speedlight SB-22S TTL Flash
Anonymous
Level 2:
Novelist:
  • Expert 88 Answers
  • Posted on Jan 26, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
88
Questions
0
Helped
35544
Points
239
No--SB-400, SB-600, SB-800, SB-700 or SB-900.
1 Related Answer
Brian Williams
  • 48 Answers
  • Posted on Feb 07, 2009
SOURCE: Speedlight SB-80DX TTL Flash ideal for NIKON D60?
It works but it's not ideal. The SB-80DX won't support TTL flash on the D60, only non-TTL Auto and Manual. The SB-800 is the most capable flash unit for the D60, but you can get full TTL operation with the less expensive SB-600 or SB-400.
2answers
Can I use Nikon SB-22s speed light with my Nikon digital SLR D5000? Is that compatible? I bought SB-22s for my previous Nikon film camera. Thank you.
You should be able to use your SB-22 with your D5000, however you can only use it in the manual mode since it is not a TTL speed light. That means you will need to manually set both the camera and the flash unit. I have done that successfully with an SB-25 on both my D800 and D90 in a pinch, but you should consider investing in either an SB-700 or SB-910. They are allot more versatile.
CAN I USE A NIKON SB-22S SPEEDLIGHT ON A sony slt a35
If you're worried about the trigger voltage, it's safe according to this list: http://www.botzilla.com/photo/strobeVolts.html.
You won't get all of the automation as you would with a flash intended to be used with a Sony camera.
Nikon d90 and spidlight sb 22 TTL not working can that spidlight be yuset on d90 or not
this flash will not work on the newer digital nikon cameras, the flash for d90 needs to be ittl compatible.
Speedlight SB-22S TTL Flash: i have a Nikon Speedlight SB 22 that was used on m...
sorry ,you will have to get a flash for digital.nikon dx type.film flash not compatible with digital.
2helpful
CAN I USE A NIKON SB-22S SPEEDLIGHT ON A NIKON D80
Yes, but not all features may work. Look in the manual under "Optional Accessories."
Sb-22 flash fires but d60 still opens the bilt in fash
I think you will need to upgrade to the 22s. It sounds like the newer model provides the D60 with a 'handshake' signal that the older 22 model does not have.
3helpful
Using a speedlight
the SB-22 has a voltage of around 4.5v this means that it will not fry you D60 SLR so the answer is YES you can use you old flash gun with your D60
5helpful
2answers
Use of Nikon SB22s as slave flash.
in the manual setting the SB-22s is just a standard flash and should work with a standard hotshoe.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
