Ok you have no pressure from fuel pump to the injectors and you replaced the pump. Sounds as if you need to check or replace the relays which send the signal from your ignition switch to your fuel pump to engage/shutoff. Warm weather area sorry doesn't really apply unless you're in an older carburated vehicle
SOURCE: 2005 F250 V10 gas Super
probly hav a wiring issue--also chec fuses and relays--inspec fuel pressure regulator in engine area--try to get a diagnostic scan from a mobile mech--a haynes manual is a must for detailed troublshootn
