Heating & Cooling Logo
Posted on Dec 03, 2010
I have a Bryant package unit that clicks when I put in the fuses. It is not a loud click that you would expect with a gas valve however. The light on the furnace control is flashing 6 times.
Donald Jordan
Level 1:
New Friend:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Dec 03, 2010
Donald Jordan
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
19
Questions
0
Helped
4379
Points
48
The codes are generally printed on the back of the bottom cover on residential units (blower section). On light commercial, the cover for the controls section (follow the line voltage and thermostat wires. Off the cuff, if it has a sparker, the flame rod at the opposite end of the burners from the sparker is usually dirty. Dress it a bit with very fine sandcloth or steel wool. If it has a hot-surface ignitor, unplug it CAREFULLY and check with an ohmmeter. If bad, it likely won't register at all. While having little to do with a "code 6", these are the "weak-links" in most heating units.
Bryant furnace
Check gas valve is not on pilot only check air filter is clean check connections to gas valve .
Whirlpoll lgr5644jq1
You need to check the solinoids on the gas vale. They might work to start but after they heat up some they possibly could break down and shut off. There are 2 coils on the valve. When you first start the dryer you should head a distinctive loud click noise. that is the primary coil opening the valve. When that happens you should also see the glow bar lighting. after the bar lights you should hear one more loud click. Thats the heat sensor opening and allowing the other coil to open to allow gas to flow and ignite. If you do not hear the first click when you start the dryer, look in the back for a small white rectangular fuse with 2 small wires on it. (they may be blue in color) That is a thermal fuse. Use a ohm meter to check if it is pen. If it is replace it.If you heard the first click and the glow bar starts to light but nothing else happens, you eed to check the heat sensor. It is connected to the flame baffle at the end of the gas valve. It will have 2 wires on it. One white and one blue I belive. It is attached by 1 screw. ( 1/4") You will need to check that out with a meter also. If it checks good reinstall it. You will then want to ohm out both coils. Only one may be bad but I recomend you replace the both of them. You will also want to make sure that your vent is not clogged up. That too can cause the dryer to short cycle. Hope this will help you.
1helpful
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
I would suspect that it is not the valve making the noise. I would bet it is the thermal expansion of the metal that you are hearing. Other than that, I have seen cases where there is a flow control valve, and depending on its operation, when it opens or closes on spring power it will over shoot and make a loud clicking noise as the clutch overshoots. This will usually only be about 2-4 clicks though, and around pool equipment I doubt you would hear much of it. I would bet more on the thermal expansion. Kind of like the clicking noise you will hear after you have parked your car and the engine is cooling down.
Wont heat
do you hear 3 clicks when you start it up,these clicks are the gas valves opening to supply the unit with gas for operation,if no clicks are heard it can be the thermal fuse is open,if only 1 or 2 clicks check continuity of the main and secondary gas valve coils as they can open up or get weak from heat during operation,usually just replace both coils on the gas valve as they are inexpensive one has 3 connections and the other has only 2 connections,but first bypass the thermal fuse with a jumper wire (for testing only) then replace the gas valve coils next,unplug both coil connections then remove 2 screws holding the valves to the valve and replace and reverse dis-assembly procedure
I have a lennox gravity furnace, circa 1946. it works fine, however, when the (gas valve??) kicks open to light the beast, it makes a loud mechanical CLICK. also when it shuts off, it clicks loudly (not as...
I would say on a unit that old it is probably just the gas valve opening and closing and as long as it's functioning I would not worry about it. Thank you.
Gas Furnace Will not light
Hi, normally when you turn the gas off at the flex line valve and leave it off for awhile, the gas has to clear the gas valve and lines up to the pilot. Purge its self of air before it will light again. It will take the electronic ignition several clicks and more before there is enough gas to light the pilot and then open the main gas valve to fire the burners. Tell me, what kind of gas furnace is this when you speak of water? you say the site glass was full and you had to drain it and then the ignitor kept on clicking when it normally only took one click to light it. Please let me know the style as in a split system, a package unit, all in one, or what you have. I will wait to hear back from you. If the pilot does not light right away, then yes let it continue to click and see if it will light. On a heater with the electronic ignition control module on it or a circuit board, this is what tells the pilot coil to energize to light the pilot. It will send power to the pilot coil to open and let gas through to light and same for the main gas valve, will get a signal to open when the pilot is on. It will not open unless the pilot is lite for saftey. I will wait for you're responce.
Shastalaker7
2helpful
2answers
I have a york diamond 90 diagnostic 1 flash lock
open the top of your unit so that you can see into the burner box
what your looking for should be an orange wire that leeads up to a metal rod
that metal rod should be in the way of the flame when unit is on
this is your flame ground,,, or more commonly known as the flame sensor,,, take this out and goive it a good brush with some steel wool
and reassemble,,
this should clear up you problem
Clicking noise at the gas valve/pilot light unit
It sounds like you might have a spark igniter on the unit that is being told to relight the burners. This is probably the tstat as this is the only control that "tells" the unit to come on. There isn't anything else internally that will cause this problem. Replace your tstat and I bet this solves your problem.
Bryant 36E93 gas package (pilot won't stay lit)
If your unit has a thermo-coupling this is most likely the issue This little sensor sends a milli-voltage to the gas valve telling it to keep sending gas for the pilot since its lit and all is good. They wear out and the gas valve thinks the flame has gone out (whick is hasnt) and kills the gas flow.
Top Heating & Cooling Experts
Paul Carew
john h
