Computers & Internet Logo
Posted on Nov 29, 2010
When i turn on my HP computer to boot up it says PXE-E61 media test failure check cable and PXE-M0F. I don't know what it means or how i go about fixing it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
141
Points
Go to safe mode using f8 then go to restore to previous date pick date when system was working and push restore
PXE-E61: Media test failure , check cable PXE-M?F : Exiting PXE ROM Operating system not found What can I do when my lap shows like this ? Give me an Detailed reply Urgently please.
Link below found using https://www.google.com gives steps to follow:
https://www.intel.com/content/www/us/en/support/articles/000005740/boards-and-kits/desktop-boards.html
PXE-E61 Media Test Failure Error for Intel® Desktop Boards Documentation
Content TypeTroubleshooting
Article ID000005740
Last Reviewed11/01/2017 What are you seeing?
The following errors display when your Intel® Desktop Board starts:
  • PXE-E61: Media test failure, check cable.
  • PXE-M0F: Exiting Intel Boot Agent.
Why are you seeing it?
PXE (Preboot eXecution Environment) is a boot environment that allows the Intel Desktop Board to boot up using a network interface, instead of booting from an installed hard drive. You can enable or disable PXE boot in the BIOS.
If PXE Boot is enabled in BIOS, the PXE-E61 and PXE-M0F errors can happen when both of these are true:
  • A bootable hard drive is not detected.
  • A network cable is not connected to the Intel Desktop Board.
How to fix it
If a drive is installed Check that the drive is detected in BIOS:
  1. Press F2 during boot to enter BIOS Setup.
  2. Go to the Boot menu.
  3. Check the Boot Drive Order.
  4. Press F10 to exit BIOS Setup.
If Boot Drive Order shows No Boot Drive:
  • Check that the drive is properly installed in the computer.
  • Try installing a different known good drive.
If PXE Boot is enabled in BIOS To check the BIOS option:
  2. Go to the Boot menu and check for Boot to Network.
  3. Press F10 to exit BIOS Setup.
If you do not plan to boot to a network, disable this option.
If you do want to boot to a network, check that the network cable connection is working properly.
tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
8helpful
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
2answers
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
3helpful
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
15helpful
3answers
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
2answers
Trying to start my computer
you have a failed hard drive and will require a replacement.
Grand Canyon Tech
Grand Canyon Tech
