NOTE: Make sure fuel tank (9002) is properly supported during removal and installation procedures.
Drain fuel from fuel tank .
Loosen fuel tank filler pipe clamp.
Remove fuel tank heat shield (9A032) from vehicle.
Support fuel tank .
Remove bolt from rear fuel tank support strap (9092) and remove rear fuel tank support strap .
Remove bolt from front fuel tank support strap and remove front fuel tank support strap .
Partially lower fuel tank to gain access and remove feed and return lines from sender ports. To disconnect push connect fittings, refer to Push Connect Fittings in this section.
Remove electrical connector from sender unit.
Remove fuel vapor hose from evaporative emission valve (9B593) .
? 7:20 www.youtube.com/watch?v=Luj6qPuxIPM Mar 10, 2013 - Uploaded by FastestIntegra
How to clean and fix a leaking gas tank. ... i repair rusted gas tanks with fiberglass putty, works really well, i have a car that i fixed 7 years ago ...
Hi faheem_najam... You probably have debis blocking the drain hole of the air compressor tank.. You will need to depressurize the tank...and remove the drain from the tank at the bottom of the tank...once you have the drain valve removed, get a stiff piece of wire and bend a small hook in the end and insert it into the tank where the valve was...and try to remove the debris with the stiff wire. Most likely your debris will be flakes of rust from the inside of the tank. Bud
The proper way is to remove the tank from the unit. You can also use a vacuum type device to remove all the fuel and water although it is very difficult to remove everything without removing the tank. Make sure you do not use a motorized vacuum device unless it is ul rated for use around gasoline!!!!
remove fuel filler hoses, support tank, remove fuel tank straps. lower tank to access fuel lines. disconnect lines and connectors.remove tank dump fuel in suitable container and dispose of properly
well first of all, it's a good thing you're draining it, because there's rust in your gas tank. Second, you're going to have to siphon the gas out, and third, use a proper technique, because i doubt that gas is too tasty
