I have a two year old Danby DCD5505W front load dryer that all of a sudden stopped drying clothes. Everything seems to functioning properly except the heat. Could this be the heating element or...??? The owner's manual is very vague, so I've had no luck there. Thanks in advance for any assistance on this issue.
Same model, same problem - we've had the unit for almost 2 years. But it looks like we solved the problem just now:
After unplugging the unit, we opened up the back and there is a little red button mounted on a black plastic box that's wired to the unit. It's a reset button - we pushed it, and the heat is back on! I hope this solution helps.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Thank you very much for your help. You saved me lots of money. I was considering bying a new dryer.
Best,
L.
I have been reseting the little red button for the last few months and now it only resets for a day or so. I figure there is something else going on. Does this sound like the thermal fuse is blown?
Wow - I'm so glad I did a google search and found this solution. I was ready to get a new dryer! Pressing that little red button solved my dryer issue!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
we R HAVING IT LOOKED @ WEDNESDAY - C HOW IT GOES.
Please post how the repair goes , as mine dryer has stopped drying also. The same happened to another Danby dryer in a rental unit next door last week. If it is a fuse, can you buy a thermal fuse and is it easy to replace, same for heating element?
Thanks
Mel
same issue, but this solved my problem. all about the red button.
does not heat up. when i firt used it on instruction it need it to be program, i lost hand book.
dryer works but it only heatup to about 89deg.
Pressing the red button totally worked, thank-you. You just saved me about $400
yee-ha!
