2006 Ford Fusion Logo
Posted on Nov 13, 2010
My cd player is a 6 disc cd player and the other day i went to press cd and it said 'no disc' so i went to the ejectdisc button on the upper left and pressed it then it said 'no disc' so i pressed the load button on the upper left and it said load cd, so i did then i heard the discs moving or something and then 'load error' or something like that.. but like i said i can hear them try to move when i start the car but it wont play after that...
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Nov 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
2553
Points
9
Remove battery -ve cable for 10 to 15 min then refix it and on ing switch press eject knob on unit. i think it will work
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
2001 honda odyssey...my radio works fine, but the CD player wont accept any discs!
If its a 6 disk cd system the cd tray is wedge causing the cd option to not work. Most of the time one of the cd slipped out of its position causing it to wedge
1helpful
Bose 6 disc cd player reset button
Acura RSX-type S where is the reset botton on a Bose 6 disc in-dash cd player. I have a CD stuck in the CD player. Need help getting it. Everything I read is telling me to push the reset button.
It's a 6 cd player I went to load the next cd in and all of a sudden the first disc is not worken
The CD loading mechanism has broken, a common failure in all CD players, remove it and send it out for repair.
8helpful
2answers
Volvo XC90 6 disc CD player reads DISC ERROR, please help!!
Try this to eject cartridge
PRESS AND HOLD eject button
Insert credit card under cartridge,push firmly in,then move left/right
Try several times ,what it does is locate a micro switch which sticks
This works on all cd stackers providing it has no other problems
Battery died - replaced the battery yesterday but now the 6 disc changer will not operate - radio and clock work fine but it's like it does not even know there is a cd player in the car. every 30 seconds...
I take it the cartridge will not eject
If so press and HOLD eject button insert credit card or similar under cartridge push firmly in and move left/right
This locates micro release switch
Make sure nobody has inserted discs upside down
How do I remove the 6 stacker CD player from the Dash board of my 2005 Hyundi Sonata. There are 6 discs stuck in it and it won't play. The radio works so it is not an electical problem to the unit
If it has a 6 cd cartridge, try this.Press and HOLD eject button, insert credit card under cartridge move left to right to locate micro switch which will release cartridge so then you can see if one of the discs has jammed.good luck.
14helpful
Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
1helpful
CD Player won't work
Try pressing the eject and load buttons at the same time, with the car ignition in the ON position. You might have to hold both buttons for 15 to 30 seconds for this to work.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
