This link will get you 2007 which should be same. Good Luck.
http://www.the12volt.com/installbay/uploads/2007DodgeCharger.txt
Check THIS LINK for CHRYSLERS TRANSPONDER SYSTEM, Requires Bypass Module; aldo this detail wiring diagrams:
- PARKING
LIGHTS ( + ) -->> Diagram
- POWER
LOCK -->> Diagram
- POWER
UNLOCK -->> Diagram
NOTE * THIS VEHICLE HAS A SPECIAL IGNITION THAT REQUIRES A PKUCH2X FOR REMOTE START.
NOTE ** THIS VEHICLE USES A SINGLE WIRE DOORLOCKING SYSTEM THAT REQUIRES EXTRA PARTS FOR KEYLESS ENTRY. SEE DIAGRAM.
NOTE **** the TIPM (Totally Integrated Power Module) is located in the Engine compartment, on the Passenger side Fender.
NOTE ***** THE WIRELESS IGNITION NODE IS PART OF THE IGNITION SWITCH
Hope helps.
What kind of alarm are you trying to install? Each alarm is different. Also does the alarm have remote start, roll up the windows and lock the doors. What all options does the alarm have?
My alarm is a Galaxy 5000RS-2W series-DBI and got remote start ,the automatic locks and trunk release, valet switch and some more that I may not used. please let me Know ifyou can help,thankyou
I got a Galaxy 500-RS-2W Series-DBI and I own a 2008 Dodge Charger That I want to installed to What I need is Crosswiring diagrams betwine the two,I know where some connections are going but to sure with others. thank you hope you can help me.
I SEND SOME INFORMATION TO YOU AND IDON'T KNOW IF YOU RECIEVED OR NOT BUT MY CAR IS A 2008 DODGE CHARGER AND THE ALARM IS A GALAXY 5000 2RS-DBI WITH REMOTE CONTROL AND I ALSO GOT THE I DATA LINK BYPASS MODULE THAT E-CARS ELECRONICS TOLD MY THAT WAS REQIRED FOR IT
