SOURCE: Acer laptop restarts repeatedly to acer erecovery management environment
did you reformat the hard drive first?if not then you needed to ensure that you selected 'repair' first.
SOURCE: how do i reboot a acer aspire 5515 laptop
What is the problem now. You have not mentioned. I suppose that it does not reboot. In that case at bootup press F8 to enter the Safe Mode. Once you are in safe mode, you can restore the laptop to pre- kids date. That will remove all the changes that the kids made whether it be the settings or any new prog installed and whatnot. To restore to an earlier date Start->All Progs-> Accessories-> Syatem Tools->System Restore. Once there, select a date (bold numbers in the calender that appears) and let it do what it does. Will reboot on its own and ultimately give you a system as if the kids had not touched it at all.
SOURCE: How can i completely reboot my acer laptop aspire
Please go to Start/click on the shutdown /and choose restart/press Enter .It will take approx 1 minutes to completely restart .
SOURCE: reboot system
my acer aspire is hang insert battery time,ac put normal work,my modle is acer aspire 5051anwxmi
Click the "Start" button found at the bottom left hand side of your desktop. Select "Turn Off Computer" in the "Start" menu options.
Click "Restart" in the "Turn Off Computer" dialog box to reboot your computer.
Watch your computer's reboot display closely. Press "F2" when you see the system keys display at the bottom of the screen, just before the Windows splash screen appears, to access the BIOS panel.
Make any needed changes in the BIOS and hit the "F10" key to save your changes and exit the BIOS. Your computer will complete the startup process and launch Windows.
