u should have told the problem more broadly.
because i don't know the type of error
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is
spelled correctly.
To check your connection settings, click the Tools menu, and then click
Internet Options. On the Connections tab, click Settings. The settings
should match those provided by your local area network (LAN)
administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set
Microsoft Windows to examine your network and automatically discover
network connection settings (if your network administrator has enabled
this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and
then click About Internet Explorer to determine what strength security
you have installed.
If you are trying to reach a secure site, make sure your Security
settings can support it. Click the Tools menu, and then click Internet
Options. On the Advanced tab, scroll to the Security section and check
settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error.
C:\WINDOWS\system\shdoclc.dll/dnserror.htm
Whenever u get this it's almost always an IP address problem. Try
renewing your ip address.
1. Click the Start menu button on the Windows taskbar.
2. Click Run... on this menu.
3. If the computer is holding a current IP address, type 'cmd'
(without the quotes) in the text box that appears. A command prompt
window appears on the screen.
4. Type 'ipconfig' (without the quotes) to view the status of the
computer's IP address(es).
5. If the computer is holding a current IP address, type 'ipconfig
/release' to let go of the address.
6. Type 'ipconfig /renew' to obtain a new IP address (whether or not
the computer is holding a current address).
http://compnetworking.about.com/cs/w...in1/ht/ht_.htm
See it this doesn't fix your problem.
perhaps you'll need to direct connect with an Ethernet cable?
Can U connect to anywhere else?
Please let me know what is the status of LAN in your computer as, limited or no connectivity, media disconnected or network cable unplugged
If you r using XP or vista, goto Start->program->accessories-?command prompt
in this black windows, type ipconfig and press enter. You will get details below that. Paste the results here. We can help you easily with these informations
