As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available
here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Thank you for your prompt and very helpful answer! That did work, and I put the pics on CD to be sure I had them. The problem was that I inadvertently had 3 videos, instead of the 3 pictures I meant to take, which must have used up the memory. Now, I can't figure out how to clear the stuff off of the camera to free up the memory. I am so befuddled, because I used to do this all the time without a hitch! Any help there? Thanks, again!
