Nintendo Wii Console Logo
Posted on Oct 02, 2010
Wii stopped working. the light is not on. There is a disk inside that won't eject. We tried unplugging and replugging everything. Could it just be the 3V battery ?
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Oct 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
Helped
2406
Points
44
Did the power go out while your Wii was plugged up and on or in sleep mode? if it was, you probably need to unplug you wii from everything and let it sit for a few minutes. your Wii probably just got 'shocked' by the sudden lack of a power source. If the power didnt go out, then I dont know how to help you~ Sorry. I hope I helped!! ^-^
1helpful
2answers
Wii console won't eject disk in console. Just makes a sound like it's trying to eject it when you push the eject button, but then stops.
something inside is faulty possibly. i would try to fdind somebody who works on those game systems and have it repaired
4helpful
2answers
Wii won't power up
Leave the wii power brick unplugged from the wall socket for 15 min then try to plug it back in. This worked for me.
1helpful
12answers
I can't my Disc to eject from my Wii Console. Does anyone have a solution to this problem, other than taking it in for service?
Try all of these steps:
1. Turn the Wii off and on again after about 20 seconds. Press the eject button again. If no help:
2. Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. If no help: 3. Hold down the eject button for 5 to 10 seconds. Still not: 4. Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. if no help: 5. See if power light was coming on and do the AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for 5-10 seconds Finally: Call Nintendo 1-800-255-3700 and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Good Luck
4helpful
5answers
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
2answers
Green light stays on, black screen, no sound, no connection w/ remotes
Go to the tv settings and check to see if you blocked any incoming devises. If you did block the devides, your tv will not read the wii
2helpful
4answers
Power is on but screen is black
I found this [temporary] solution at http://www.wiierror.com/wii-black-screen.php:
(via email, thanks Steven) This happened to me once, but I fixed it. Here is how:
Eject the disk
Unplug the wii at the back
Wait 1 minute
Plug it back in
Turn it on from the remote
Press reset if it does not show up
Hold the power button to shut it off
Turn it on once more.
I don't know how, but it seemed to work for me. The problem happened when I was trying to load the Mii channel. Hope this helps !
(via email, thanks Andrew)
The first time I shut down my Wii, the light went orange (as it should). When I turned on the power with my wii remote the next day, the wii\'s light turned green but the screen was black.
The treatment was the same as from Black Screen, No Connection: Unplug the Wii\'s power supply unit, then replug; turn system on with wii remote.
The difference is: this problem can strike in more places than just by loading the Mii Channel. Also, I think the green light being on (yet there being a black screen) is a common symptom as well.
Wii
hello micky1965
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform:
| Nintendo - Customer Service | Contact Us! |
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
riz.
althought i have a guide for opening inside the wii.?
49helpful
21answers
Wii Power, Wii Goes Dead when I press Power or Eject Button or Remote Power Button. Is THIS AN INTERNAL DAMAGE
According to Nintendo u can try this. 1. push the reset button and if that doesn't work unplug all cords and memory cards (including sd) from wii and unplug av from the wii and the outlet in wall. Wait 2-3 min and then plug it back in. Thats as far as i got because that fixed my problem hope this helps someone!!!
476helpful
25answers
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Wii won't work after "incorrect memory card" was inserted.
you shouldnt need a memory card to save wii games it has 512mb internal memory.unless your trying to play gamecube games on it.the wiis security features are incredible if it cannot recognize a controller or memory card it will power down.make sure you are using a SD memory card because it will not accept anything else.it will power down for safty reasons.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
