SOURCE: 99 hyundai sonata airbag light and reset.
There are no campaigns/recalls for the SRS (Supplemental Restraint System - Air Bag). However, there is a Service Bulleting regarding the wiring harness under the seats:
DESCRIPTION:
Motion of the side impact air bag wiring harness and connector may result in illumination of the air bag warning light and one or both diagnostic codes listed below:
This campaign provides a new side impact air bag wiring harness connector mounting procedure.
VEHICLES AFFECTED:
SPECIAL NOTES:
The service procedure to be followed depends on the original wire harness routing under the seats. The required parts are different for each procedure.
If your vehicle doesn't fall within the production range, it's not affected.
I recommend you take the vehicle into a Hyundai Service Department and ask them if your vehicle has had this repair already. If it doesn't apply, pay the diagnostic fee to find out what the problem is. They will give you an estimate of repairs (parts, labor, tax, time-frame, etc.).. Then you'll know what the problem is.
SOURCE: how to remove airbag light its staing on 2007 hyundai sonata
You can try disconnecting the battery for 30 minutes or so, then hooking it back up, but usually an airbag fault warning has to be actively reset with diagnostic software.
SOURCE: airbag came on for no reason why 2001 hyundai
Here's a quick check list
for most common cost of SRS / Air bag problem.
Dirty contacts on driver
and passenger seat belt buckles
Dirty contacts on seat belt connectors
(under seats)
Dirty contacts on driver and passenger sides weight
sensors (under seat)
Seat covers
Weight on passenger seat
(Example:
grocery package trigger SRS / Air Bag light on the way home.)
I
recommend you to pass an vacuum over the contacts and use CRC
electronic parts cleaner to rule out connectivity problem.
I DO NOT
recommend disconnecting the negative battery connector to clean the code(s).
Without the code(s) the dealer will takes "BILLABLE" time to reproduce
the problem.
Please rate my answer if it is useful to you.
Cheers,
Mustgo
SOURCE: 03 hyundai sonata air bag light stays on
I read on another site to check the "yellow" connector under the passenger seat. Connector ncould be loose or wires that go in the connector may be loose.
SOURCE: the airbag light stays on
The codes will have to be read from the system to find the problem.
