SOURCE: i have a volvo v40s 1.8 petrol estate on which major oil leak
in my opinion your engine is a goner,
SOURCE: 1990 volvo 240 front oil leak cam and crankshaft
It is not a solution, but as long as there is oil in there, you are good. Just make sure you keep a good eye on it, just in case it gets work. Best wishes. If you need anything, let me know Bob. I am always here.
Testimonial: "Thank you rickyrt441 Have oil will try repair this weekend bob"
SOURCE: my 1998 volvo s70 overheated
If coolant level was good and no leaks as you said...my next check would be the proper operation of the thermostat.
SOURCE: coolant leaking into floorboard on 1999 volvo v70
If you've got coolant coming into the car, then its probably the heater matrix which has a hole, either in the small radiator or a hose (Behind and below the dasbhoard). Invariably a nightmare to get to.
If you're using/loosing oil. Then check the tail pipe, if there's blue smoke coming out, the engine is burning oil. Usually valve guides or worn piston bore..
SOURCE: My 2002 volvo d12 wont start.
I suggest you use VOLVO VIDA DICE Diagnostic Tool check the engine,
look what's wrong with your engine.
