2007 Hyundai Sonata Limited Sedan Logo
Posted on Sep 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace my owners handbook. 2007 sonata
Anonymous
Level 2:
  • Expert 502 Answers
  • Posted on Aug 13, 2011
Anonymous
Expert
Level 2:
Answers
502
Questions
0
Helped
424580
Points
952
A
Anonymous
Click on this link below and then locate the "Download (2007-hyundai-sonata-owners-manual.pdf) link and click on it to download the 2007 Hyundai owners handbook
http://pdfservicemanual.com/automotive/2007-hyundai-sonata-owners-manual
1helpful
Where is the fuel pump relay for 2007 Toyota Yaris
try google images for a picture of the fuse box, try ebay for an owners handbook which you may need in the future?
Hi I have a Citroen berlingo 2007 and the cigarette lighters don't work what number is the fuse and is it under the bonnet or steering column. Thanks in advance
You can download a handbook for free on this site.
www.citroendriveeeurope.com.au/wp-content/uploads/2013/10/Citroen-Berlingo-Owners-Handbook.pdf
Keyfob works but no sound sonata 2007
Check owners manual. There maybe options for shutting off and turning on the beep using the remote. A sequence of button pushes on the remote for Honda as well.
Replacing the serpentine belt on my 2007 Hyundia sonata; which way does the belt run?
Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop & owner manuals, service bulletins, campaigns, illustrations and procedures, etc
Where is the fuse for diplights and watts
The fuse must be in the main fuse box. The position of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown one. To help with your search, the head light fuses should be between about 10 amps each if you have separate fuses for each light..
TUNE UP
Theres is not much to do as far as replacing parts.
The owners manual that came with the vehicle will have a service interval for maintenance. Spark plugs, Fuel filter and air filter are good places to start. Also transmission fluid change and tire rotation. Of course this all depends on the mileage the vehicle has.
My hyundai 1.6 petrol matrix has intermittant
answer from the uk.you will only have a problem showing up if the engine management system records a fault within that system, so, the only solution is, if you have remote locking,change the batteries and use to unlock car not using the key.or if no remotes,change keys on a regular basis.(they are coded to the car) do not use grey (service key) only 2 x black keys supplied with car....check handbook re keys....
Programing a 2007 Hyundai Sonata to open a garage door
It's in your owner's manual - plus!, THERE'S A 1-800 number to folks to HELP you PROGRAM your GARAGE DOOR opener.... amazing the number of people who don't read.
Headlight need adjustment
there is an adjustment screw on the back of the headlamp assembly. check the bulb and make that is installed straight with the metal tab lined up inside the hole.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
