It appears that you may have an intermittent earth connection between the globe sockets and the vehicle body.
First, check how well the metal base of the globe fits into the socket. If it is a bit loose remove the globe, squeeze the sides of the metal socket with some pliers so that the globe fits snugly in the socket. If it is still not working correctly, check the earth wire that runs from the globe socket and any connectors in the wiring loom near the Light Assembly as well as where the earth wire is attached to the body. Remove, clean and re-attach securely if necessary.
