Test your PSU or replace it
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Check the ram chips and make sure video card is secured. if you have to try and only boot with a single ram chip and try it in the other slot in case the 1 is bad
a bad power supply will not cuase the error beeps . the short and long beeps mean something so count the long and short and the info can be found on the web also
When
you plug in the power cord is there any lights whatsoever on the laptop, where
the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,
lights on the computer, hear any beeps or lights constantly blinking, hear the
DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a
second or two? If so the computer is trying to boot or may have booted,
but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the
laptop and why it is not booting. Most times it's a motherboard issue
when you hear beeps or blinking lights continuous. Most times the problem
is with the memory or Video Card. Count the Blinking Lights or Beeps and take
note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge
Buildup. Remove the Power Cord, then Press and Hold the power button for
30 seconds. After 30 seconds plug the power cord back in and hit the
power button to see if it boots.
Maybe
your memory is bad or the memory slot is bad.
Remove
the Power Cord, Open the Case and remove one of the memory chips. Set the
chip aside then try rebooting the computer. If it boots, then you know
the memory chip you set aside is bad so mark an x on it with an ink pen.
If it fails to boot then move the chip to the next memory slot and try
rebooting. If it fails take the chip out and set it aside, then put the
other chip in and try booting it in both slots. If it boots, just to
verify that the chip set aside is bad, mark an x on it and put it into the open
memory chip slot and try booting.
The computer does fire up, however I am not getting a signal to the monitor....... could this be related to the contstant beeping sound
