A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Please make sure that you have allowed exceptions on your Firewall/Antivirus for magicJack. The most common Firewall/Antivirus programs are listed below. If your Firewall/Antivirus software is not listed, please refer to their web site or user manual.
You can download a document (pdf file) from MagicJack by going to
In order to receive calls, you must turn Notifications on for your magicJack APP.
On your iPhone/iPad/iPod Touch, go to Settings, Notifications, and select magicJack APP
Make sure that Alert Style is set to Notifications and Sounds are turned on
You can also shut down the magicJack APP by "double-clicking" the "Home" button on your device, tapping and holding down the magicJack APP icon, and then tapping the "X" icon in the top right corner of the magicJack APP icon.
Once the magicJack APP has been shut down, you can re-launch it by tapping the icon.
The screen will dim on battery power to save energy. The power settings, found when you right click the power icon in taskbar notification area and go to power options, can be changed to your personal preferences. The shut down issue may be what is running, I can't say what is running, but look at the Start up process in MSCONFIG and shut down what is not necessary at Start UP. Look at tutorials on Faster Start up and Shut down. There may be many items you can shut down/disable to speed up these events. QUESTION: Is this a upgrade to WIN 7 Ultimate, If so your computer me be a bit short on specs, in other words you have reached the computers hardware limits. How much RAM, CPU speed...etc.
Assuming you are using windows XP on this: Create a new folder in "my pictures " folder Copy the images you want to use into there On your desktop, RIGHT click and choose "properties" to open the display settings Click "Screen saver" and choose my pictures slideshow Click "settings" to open the options for this Click browse to point to where you saved the images Set the duration and timings to suit your tastes Exit by clicking Ok and the OK to exit the display settings
The device requires restoration achieved in two processes
perform a check
1. Power off completely the camera.
2. Remove all power devices or batteries
3. Check the entire device for damages
4. Make observation notes about any malfunct features
5. Replace batteries and removeavble parts properly with caution that every feature is intact.
6.If the device still displays error message consider the second phase explained
a. The device program features are jammed only possible solution is performing a software update or upgrade
1. updates are achieved by contacting the device;s technical support deparment
2. Upgrades can be performed by acquiring an installation kit in which instance requires technical expertise to perform an intergration restoration
Important notes
1. Apart from the message received does the device malfunction?
2. Your camera would be displaying an image similar as flash screen or screen saver that can be fixed quiet easily
a. use the menu buttons to select the option of settings
b. set the picture to be displayed on the appears screen area once powered on.
c. Possibly alter the entire image displayed as desired by yourself.
4. A screen saver could only be deleted,, hidden, or replaced with a preferable image
5. Possibly, the words ZOOM ERROR could changed to WELCOME TO OLYMPUS STYLUS
CONTROL PANEL
THEN DISPLAY
THEN SCREEN SAVER
You will find your settings in there
and will be able to set your screen saver then if you click settings at the top then power you'll be able to set when your hard drive and monitor shut off if you need more info just let me know
your display card might have gone........ go to a nokiashowroom and they will provide u a beter soln............ if the mobile phone has fallen many times, this problem occurs..........................
