Hello marychartran, Here is the link to your manual: If this happens to be the wrong manual post a reply. I cross referenced the common name with the part number to find it. The file is in PDF format. If you found this solution helpful please rate it. Thanks! Edward
After digging around on the web, the closest manual I can get to your model (944-604810) is:
It seems that your model is not listed anywhere. Hopefully this helps out a little.
Thanks for reply Edward J, however, I neglected to give you the model # which is: 944-604810. The manual you suggested is for a different model. Can you suggest something for 944-604810?
