SOURCE: 98 dodge ram 1500 4x4 wheel bearing replacement
Yes those are bolts. You remove those from the back side. This takes a while sometimes. If you can't get them by reverse alone, try hitting them with impact in forward for a hit or two to brake it loose a little. If the new hub comes with new bolts, don't be afarid to brake them. PS, after those bolts are removed, don't forget to remove the nut on the axle shaft. You may also need to use an air hammer to help remove old hub after bolts are removed.
SOURCE: 93 dodge spirit engine noise
Remove the drive belts, then spin each pulley by hand. You should find one that feels wobbly or rough. This is the component that is most likely causing your chirp. Usually it is either the water pump or an idler pulley. DO NOT run the engine with the belts removed- the engine will overheated and severely damaged!
SOURCE: 1999 dodge durango 5.9 v8 loud squealing noise
You didn't mention the alternator, power steering pump, or water pump. In fact, any pulley other than the crankshaft one can have a bad bearing or dry seal. Remove the belt and spin each pulley while listening for any rough noise or squeal. If it was the crankshaft, it might be time to check the oil. Start the engine with the belt off to see if it does squeal. Make sure the noise isn't coming from the radiator fan(s).
SOURCE: 2001 Dodge Dakota replacement serpentine belt too short (w/o air)
the parts store can give you a bigger belt just give them the part# of the belt thats to small which they have a book with the measurements of the belts, tell them you need a belt the same design but 3 inches bigger, its simple, they look in the book and get the belt i do that often at napa auto parts, some part stores have lazy workers, they dont take time to help people, try that, good luck.
