I have a i465 clutch and i have previously changed my security code.....it was 000000 but i dont know what it is now......is there a way i can change it?
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safest way.unlock using software delete some information in memory i unlock my phone using codes ,i got codes from http://www.onlinegsmunlock.com/motorola-clutch-i465/rs7wp9/ you can unlock your phone here I used codes to unlock my cell phone. i had my unlock code and my phone was unlocked. you need to specify the country and network provider
If you dont know your Unlock code try this:
First press the Menu Button
The screen should change from Unlock Code to Security Code
At this time you should enter 000000 it's the default security code
Once you do this your phone should unlock.
Unlock Code is a manual hard-lock on handsets which requires the correct pass code to allow access to the phone's functions.
Occasionally, people purchase used handsets. Previous owners may have locked the handset and are unreachable to get the new pass code
To unlock the phone using the factory default pass code, perform the following:
1. Confirm the phone shows, Enter Unlock Code. 2. Press the MENU button. The screen will show, Enter Security. Try both. 3. Enter last 4 of PTN, unless you have changed the lock code, and press OK. OR Enter six zero's (000000) and press OK. *If successful, the screen will display, Phone Unlocked. *If unsuccessful, the screen will display "Security code is incorrect please try again."
If the you don't know the code, You will need to contact Motorola to have it re-flashed, which may incur a service charge from Motorola.
4. You now has access to use the phone’s functions. 5. Do not change the Unlock Code.
Try code 1234 or 0000. If that does not work go the screen displaying,
Enter Unlock Code, press the Menu key, top center, at the Enter
Security Code screen enter 000000. If this code has not been changed
you should see the previous owners phone number. If this is so use it
to try and unlock the phone.
try all the default security code 12345,1234,0000(4 zero),000000(6 zero),00000000(8 zero) ... if you have not changed the security code previously then only you can try from the above codes ...
atleast one will unlock your phone within those codes ....
any doubts reply me i am always here to assist you thank you bye rate my solution
