I have an HTC Touch Pro 2 and the font size on my text messages randomly switched to like extra small and I can't figure out how to get it back to normal.
The phone itself does not have an option to make all text larger. For text messaging purposes download the application "Handcent." It is a better text messaging application that gives you the option to increase text size. After installing Handcent. Go into it then go to settings (press the menu button), then custom
style and then bubble settings, then you have options for incoming and
outgoing font - click on those 2 (one at a time) and in the bottom right
hand corner it will give you the option for text size.
Hope this helps!
Also, for webpages, You can just use the pinch and zoom feature. Pinch your fingers together where you want to zoom and pull your fingers apart. That will zoom in on the area you would like.
I started checking I
figured out that if you move your fingure around the circle while
texting that it changes your font size. You don't have to go to your
settings or anything like that at all. Just run your finger around the
circle one way or the other and it will change font size. Hope it helps
When you rub your finger around the center/ok button, it causes the fonts to get bigger/smaller. The same happened to me and then I realized it was my finger causing the problem.
I was having a similar issue only my text was getting bigger. I found this link and it answered our problem and it also had other useful information: http://news.softpedia.com/news/HTC-Touch-Pro-Review-97938.shtml
The HTC Touch Pro supports SMS,
MMS and email. Thanks to the 3D interface, users will be able to thumb
scroll longer messages in the Inbox. Dynamic font resizing (zooming
in/out with the scroll wheel) is also available. HTC Touch Pro also
offers Message delivery reports in its Settings menu. After reading that I tried it out on one of my text messages and sure enough it changed the font just like it said it would. The center button allowed for the zooming in (bigger) and out (smaller). All you had to do was run your finger around it in a clockwise and/or counter clockwise motion.
Yes this is a problem with many people I have come across. Even on the highest setting, the font isn't as big as it was on the Mogul or Tilt devices. To set it to the highest setting, you can go to Settings-->Screen-->Text Size==> Adjust as needed.
