Samsung S630 Digital Camera Logo
Posted on Aug 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The pictures have horizontal lines
Before taking a shot, the picture has no lines. But upon capturing the picture, the image has horizontal lines. The camera was never dropped
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Aug 03, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957630
Points
33084
This is electronic shutter problem that is the reason you get blinder effect/ noise on picture. Electronic shutter is located in lens mechanism and lens assembly will be replaced to solve the issue. Nearest Samsung service center or local camera repair shop will help you to replace lens assembly.
Thanks.
Grand Canyon Tech
Level 3:
  • Samsung Master 3,867 Answers
Grand Canyon Tech
Samsung Master
Level 3:
Answers
3867
Questions
Helped
1177336
Points
12717
What it sounds like you got here is a issue with the CCD Sensor, Now sometimes the CCD will show on the output viewfinder and sometimes after its been captured. You might want to have it looked at by a local camera shop to confirm my ideas.
thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Laptop image is opposite when you capture images
Look at the settings of your camera Application and look for Mirror Image and put a check on it to get the exact image captured instead of having the image as the opposite when taking pictures or recording a video.
If not Mirro Image there should be an option for flip image horozontal and flip vertical, you just need to put a check on the Flip horizontal image or Mirro Image this depends on the Brand and the application as well of the Laptop this should correct the camera settings.
Most laptop cameras are now using a different format and needs to be set up on the application to get the mirror image of the snap shot or recorder video as what you are expecting.
I hope this helps.
When I take a picture,it does not appear anything.
when I take a picture, the only thing I see in the image are horizontal lines and no picture.video camera is working fine.
1helpful
When turning on the camera to take a picture, many times there are horizontal lines in the view finder. Taking a picture captures these lines, not the image
The imagery board need to be replaced, The camera has been dropped. I had the same problem with mine. Send it back to Fuji they will repart it but they will charge labor.
2helpful
Hi, I seem to have a problem with my Finepix Z1 digital camera. When I take a shot it seems to work ok, and the initial review image seems fine as well. But when I go back and review the image on the...
The clue is with the video.
The video function does not use the shutter. Lines on photo's or over exposure is due to the shutter not closing completely over the lens when you take a picture.
It will require cleaning which means opening up your camera and accessing the lens unit
Horizontal lines on the screen after the picture is taken
Remove the Battery from the Camera then press and hold the power button for 30 seconds. Then, reinsert the Battery pack and turn on the Camera and reset it to the original factory settings by selecting the "Initialize" option under Setup1.
If the issue persists then service will be required.
2helpful
My canon a470 produces a blury image after taking the shot.
hi,
you must have a lance problem,so please contact any authorised person for repairs , its may be a lance flap is cracked,
Display of my Cannon Power Shot SD 630 Digital ELPH: NO IMAGE
i think you camera,s software is corrupted
go your canon customer center for repair it
1helpful
Horizontal lines across pictures
Probably a problem with the chip - this model had a recall and free fix...contact the manufacturer for details
Sony Cyber-Shot weird lines, dosent like bright light
It is a bad ccd it need to be replaced some time you can get lucky by resetting the camera in the setup menu.When you take a picture the image is transmitted throught the ccd and translates the image to the cameras memory. It can be fixed. Or you can upgraded. Some places might offer a trade in value on your camera even if it is broke.
Why does the camera take so long to take a picture?
You may be pressing the shutter all the way down at once. This forces the camera to focus, make exposure adjustments, and capture the image all at once. By pressing the shutter button partially to focus, then the rest of the way to capture the image, your camera can process pictures more quickly. You can turn on quick shot mode to take pictures quickly.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
