I cannot my pair my phone with my Parrot v5.11 c i have tried passcode 0000 and 1234 could you advise of the correct code or what I may be doing incorrectly? thanks
SOURCE: Passcode/pin for my motorola bluetooth-H550
It has to be 0000 because no one can change it its set by motorola are you trying to pair with your phone?
SOURCE: Pairing CK 3100 first time with HTC touch
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Parrot device and click add
6) You will be required to enter in a pass code which is standard ‘0000’, but try '1234' again if that doesn't work
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
SOURCE: bought new van with parrot ck3100
You need to delete the existing paired devices from the setting in the parrot before it will allow new ones.
