The recoil starter on my Briggs & Stratton model 196432 engine is not engaging the clutch or turning the engine over to start. Should I start the troubleshooting by replacing the recoil starter, or by pulling off the flywheel shroud and inspecting the clutch/flywheel nut assembly? Thanks for your help. Andy
Andy, Hi, well I would start at the Starter myself, usually the thing called the "Bendix" spring jams up and stops it dead. Pull of the Starter, and power it up, off the unit. This will show you if it snaps in and out.
Sometimes a few judicious whacks with a soft hammer will sometimes free up the spring, if thats is indeed what's wrong. Anyway try that first. before any disassembly.
Make sure the Motor CAN actually be turned, by turning the flywheel, this should show you if the Motor is "Free" enough to move.
Also check ALL electrical connection to the starter. Use a meter and see if you are actually getting a voltage to the starter too. make sure your starter battery is good too.
Below is your support site, for any manuals or parts required.
http://www.briggsandstratton.com/maint_repair/
Most of this response was directed at the assumption that I have an electric startet on this engine, which I don't. Hence, it was of no practical value. Just gotta figure out how to address the recoil starter problem, i.e. pull rope starter not engaging. Andy
