1999 Pontiac Grand Am GT Logo
Posted on Jul 20, 2010
I have a 1999 pontaic grand am gt. when the car idles it stays under 200 degrees but when i put it in gear all the coolant flushes out of the overflow valve. the engine starts to shake alot. what do i do to fix this.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
813
Points
15
Check ur thermostat see if its working if not check oil and see if water is in it may have blown head gasket
2answers
How do I fix a thermostat that sticks and temp goes to 250 degrees on a 1999 Grand Am. I put a new thermostat in
New thermostats do not stick. With the radiator full and the cap off check for air bubbles at idle. blown head gaskets blow bubbles
1helpful
Blower control
Sounds like a thermostat and/ or the system is low on coolant.
Its probably not going to reach 200 degrees when the outside air temp is below freezing, but you should get plenty of heat if the system is working correctly.
My 1999 grand am gti is loosing antifreeze coolant into the engine. what can be the problem and is it expensive to fix.
head gasket, under $800 bucks, stay away from dealers..... and after this change coolant every two yrs and don't overheat it ....
2answers
Once the car gets to op.temp it starts to run rough
it sounds like you might want to scan your vehicle for sensors evaluation to determine what causing your rough idle if you have engine light on
1997 pontiac grand am coolant fan not coming on when it needs to. Put new relay on as well. fan does work. what to do next?sometimes it will be on and also stay on but when car cuts off and go to cut back...
coolant fan should kick on when engine coolant reaches 190 to 200 degrees.the coolant temperature sensor resistance will drop.closing contacts allow the pcm to signal or turn on coolant fan.if coolant temoerature sensor is open or bad the coolant fan will not turn on.need to replace it.
3helpful
4answers
99 GrandAm GT v6 3.4L overheating
Can't give you a definite "fix" only because I'd need to do testing. But, two items you need to have checked are: 1. have a hydrocarbon test done fro the cooling system to verify that you do or don't have a head gasket problem. 2. have someone check the radiator with a "heat gun" to see if there are any cold spots. Home flush kits and sometimes even shop flush equipment will force cleaner around, not through heavily plugged areas and not clear the obstruction. Heat gun is best way of finding cold areas that are not flowing.
also...you mentioned fan relays...does the fan come on?
Coolant Leak
it could be your thermostate . i do dont think its your intake.as far as putting the cap on to tight.. they are sopuse to be tight so you did not hert it . have a nice day
99 pontaic grand am
sounds lie you might have an IAC valve problem
Low coolant lite.
I also own a 99 grand am 3.4L
The coolant fans will not come on until the engine temp gets to about 220 degrees.
if they do not come on the relays are located under the hood in the covered panel near the LF strut tower.
also the fans should run constantly when the A/C is turned on.
good luck
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
