CarGurusJul 11, 2013 - Truck suddenly stops running, acting like it's out of fuel. ... start it and let it run until it dies then check the pressure and shut the key off. ... Was running fine and then turned off as if the ignition was turned of. .... Well mine was a loose battery connection that just shut down the vehicle completely while driving.
CarGurusAug 29, 2011 - I let it sit for a second then tried to start it back up and it wouldn't start.... 2006 ram 1500 randomly dies while driving 13 answers ... truck started outrunning fine but would randomly die. wait a few ... Used GMC Sierra 1500".
CarGurusJul 28, 2008 - The truck starts and dies. Have to give a little gas to keep running.While driving have to 2 foot it so it won't die. Wants to die when I come to a ...
Take it an have it diagnosed rather then looking for a magical fix on here ! Without testing , viewing scan data ,we would only be gussing . We could suggest a number of thing's that could cause this . Are you willing to replace parts that may not fix the problem. (waste of money ) !
code p 0654 refers to engine rpm output--circuit malfunction ===causes wiring ---ECM
code p 0650 refers to malfunction indicator lamp(MIL)--circuit malfunction====causes wiring --MIL---ECm
also refers to crankshaft position/cam shaft position sensor bank 1 sensor A --correlation===causes wiring---CKP sensor ---CMP sensor--mechanical fault
You triggered the antitheft security system. I'm pretty sure you will have to take it to a dealership to get it reprogrammed so it will start. You should call ahead to make sure there is not another option.
Sometimes it takes a few on/off cycles for things to reset.
You could unhook your battery for about a half hour then reconnect. This should help your computer forget the problem.
There is a solenoid that open and closes with 12 volts, usually located close to the fuel filler tube area. This open to allow you to fill your tank, then closes after some inputs for the computer are satisfied, and then a pressure sensor verifies the system is working. First, make sure the cgas cap is tight, and if the light doesn't go away in a couple days of normal driving, get the solenoid checked.
