Because of WiiConnect24 your Wii remains in standby mode when you think it is turned off. Standby mode causes the Wii to overheat and fryes the GPU. After this happens, dots and lines will be displayed on screen. Your Wii is damaged.
the tv has a bad panel you can go to the web site put in your model number and look for a firm ware update but it may not fix it i have been working on tvs a long time all the ones i have seen needed a new panel/screen witch cost to much to fix
Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote. If the Wii Remote Jacket is being used, verify that it's securely in place on the Wii Remote. If the Wii Remote Jacket is askew, it might be partially blocking the infra-red sensor on the front of the Wii Remote.
Try a new set of batteries. Occasionally weak batteries can cause this type of behavior.
Reset the Wii Remote:
Take the batteries out of the Wii Remote, wait for one (1) minute, and then re-insert them.
Wait a few seconds before pressing any buttons to wake up the Wii Remote.
Re-sync the Wii Remote by using the steps listed above in the white box titled "Try these steps!".
Check the Directional Sensor Functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
Verify Sensitivity Setting dots: Go to the Sensor Bar's sensitivity setting in the Wii menu.
If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If both dots appear and the erratic behavior continues even when you move closer to the TV, there is likely a problem with the Wii Remote and it will need to be repaired.
Click on the blue arrow to reach the Wii System Settings 2 menu options.
Choose "Sensor Bar " and select "sensitivity"
Use the Wii Remote to get the cursor to get the two white dots in the test field.
If you see two blinking dots, then the sensitivity is currently set correctlyIf you don't see two blinking dots (they don't have to blink at the same time), adjust the sensitivity with the + and - buttons of the Wii Remote until you see two blinking dots.
Select "Confirm" to save the setting.
Please note that the higher the sensitivity setting, the more sensitive the Sensor Bar becomes to sunlight and various light sources. This may impact the operation of the Wii Remote. The initial recommended distance for using the Wii Remote Pointer is 3 to 8 feet from the Sensor Bar. Seeing more than two dots? If you see more than two dots on the Sensitivity screen, then the Wii Remote is picking up on additional light sources. Verify that there are no bright light sources, including sunlight, behind or near the TV, shining towards the Wii Remote or reflecting off the TV screen. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
This information comes directly from Nintendo's website. Hope this can be of help:
First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info).
Make sure you are using fresh batteries in the Wii Remote.
The Wii Remote Controller should be used between 3 to 10 feet from the TV.
Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
This was caused by a defect in the optical block of the TV. It will only get worse with time and the only way to fix it is to replace the whole optical block which is very expensive (over $1000 usually) and time consuming (you need to take the whole TV apart). However, since it was a defect, there was a class action lawsuit that caused Sony to extended the warranties for certain models on the optical block for parts and labor. Call Sony to see if your model was one of the ones they extended the warranty for.
This is a manufacturing defect that happens to about 50% of Wii Consoles. It is caused by the lack of fan cooling while the console is in standby mode. The networking card creates excess heat that damages the graphics processor. This is an extremely common problem (happened to my own console!) and Nintendo will repair or replace your console for free if it is still under warranty. Outside of warranty, I think the repair costs around $75.
