2006 Dodge Stratus Logo
Posted on Jun 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My horn just quit working today. Been working
My horn just quit working today. Been working fine until now. Fuse is fine, and relay clicks. What could be wrong?
hangfire0425
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 58 Answers
  • Posted on Aug 18, 2014
hangfire0425
Expert
Level 2:
Cheetah:
Night Owl:
Answers
58
Questions
0
Helped
17212
Points
104
Run power and ground jumper wires to the horn to check it. If it's good swap out the horn relay with another to check it. Sometimes they will click but not make contact.
Ronny Bennett Sr.
Level 3:
  • Dodge Master 6,988 Answers
  • Posted on Jun 26, 2010
Ronny Bennett Sr.
Dodge Master
Level 3:
Answers
6988
Questions
Helped
2287688
Points
21993
If the relay is clicking,then the horn is the problem,make sure it has a good connection,if so,replace the horn.
1986 toyota pickup horn malfunction
hi
Check whether power is coming to horn.
if ok means then check the horn
thank you
My horn quit working. How do i fix it?
Start by checking the fuse as it is the easiest place to start. If fuse good, you need to check for power and ground directly at the horn itself. Some horns are not very accessable and are hard to find / get at. There are a variety of possibilites that can cause a horn to not work.....
fuse
relay
horn unit
horn pad
clock spring
wiring
body control module
It may be necessary to have a shop look at it due to the complexity of todays electronics
2answers
Horn not working
what,kinda vehicle do u have,ck fuse,ck relay, find horn&run a jumper wire to it to see if it works,
1helpful
2answers
My horn doesent work
WITH KEY ON EVERY THING ELSE OFF PUSH THE HORN YOU SHOULD HEAR A SMALL CLICK THAT THE HORN RELAY IF SO TEST FOR POWER AT THE HORN MAKE SURE IT IS STILL CONNECTED IF POWER IS GOOD REPLACED HORN
2helpful
2answers
Horn just quit working.
Do you get a click when you press the button? The relay should be audibly clicking if it's working.
If it is clicking then I'd check the horn itself, might be bad or have loose connection. If no clicking sound at all then I'd suspect bad relay or fuse (if it has a dedicated one), also possibly bad switch.
2answers
2004 Buick Century, horn quit working, replaced both horns and checked the relay (it works). The horn still does not work. Could it be the switch in the steering wheel? How do I get the cover off the...
Start by having someone press the horn while you feel the relay with your finger. If the relay clicks when the horn is pressed then the switch is working properly and your problem is between the relay and horn assembly.
1helpful
Horn Relay replaced multiple times in a few months
Actually you use the horn relay a lot! At least 3 times every time you get lock/unlock your car (6 toots, 2 toots for lock and 1 for unlock right?) ... You just said: "as i clicked my car to lock. It got weaker and weaker until it stopped working" Buy a different brand relay (preferably one not made in China, pay more) and don't expect they WILL last a long time the horns take a lot of power and they have a very dirty feedback to the relay un-like lights. You can dis-able the toots by reading your owners manual.
Horn Stuck
If it happens, you can just disconnect the fuse for the horn, or relay. It could be the switch underneat the airbag or clockspring.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
