Kodak EasyShare M530 Digital Camera Logo
A
Anonymous Posted on Jun 11, 2010
How do i delete pictures? The manual is no help.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Jun 11, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2201057
Points
38521
To delete one picture, bring it up on the screen and push the button with the garbage can icon. Follow the on-screen instructions. To delete all the pics, go into the menu and find "format"...follow the on-screen instructions.
I have a Panasonic Lumix DMC L580 and it states that the memory is full. As i dont have a manual how do i delete what is held in the memory please cheers
Are you sure of the model number? I can't find anything about a Lumix DMC-L580. There is a Lumix DMC-LS80. Make sure that you save any pictures before deleting them. Also make sure to have fresh batteries or the camera connected to AC power. If the camera runs out of power, the process will not complete.
To delete pictures from the internal memory, slide the recording/playback switch down. (The switch to the upper left of the arrow keys on the back.) This puts the camera in Play Back Mode. Use the Up/Down arrows (if needed) to select normal playback mode and press Menu/Set (in the center of the arrow keys). The delete button is the one on the right side below the arrow keys. Use the left/right buttons to select a single picture. Press delete. Press the left arrow to highlight Yes. Then press Menu/Set to confirm deleting the image. To delete multiple pictures, use the down arrow to get to Multi Delete or All Delete (instead of the left arrow). Press Menu/Set.
For All Delete, you may see an option to choose All Delete or All Delete except (star). The star indicates Favorites. If needed, pick one, press Menu/Set. Use the left arrow to select Yes and press Menu/Set again.
For Multi delete, use the left and right arrows to navigate through the stored pictures. Press the down arrow to select an image to delete. When you have marked all of the pictures that you want to delete, press Delete again. Press the up arrow to select Yes and press Menu/Set to initiate deleting these pictures. (Note: if a picture is protected, pressing the down arrow will result in On icon blinking red.)
The manual for DMC-LS80 is available from Panasonic support here: https://www.panasonic.com/au/support/manual-download/imaging/lumix-cameras/dmc-ls80.html . The current link to the manual is https://www.panasonic.com/content/dam/Panasonic/support_manual/Digital_Still_Camera/English_02-vqt3-vqt9_other/DMC-LS80%20Operating%20Instructions.pdf . See page 20 for the section on selecting the mode. See page 35 for deleting pictures.
I hope this helps.
(if you have a memory card in the camera, you will need to do the delete steps in two steps. Delete all (or multi) pictures from the internal memory and the memory card separately.)
1helpful
How do I delete pictures from a coolpix S4000
To delete individual pictures: while viewing the picture, tap the trash can icon on the screen, then tap yes when it asks for confirmation.
To delete all pictures on a memory card: format the card. TAP MENU, tap the wrench icon, select "Format card."
To delete all pictures in internal memory: format internal memory. Tap MENU, tap the wrench icon, select "Format memory."
The delete instructions are in the "Deleting Pictures" section of the manual (page 33 in my copy). The format instructions are in the "Format Memory/Format Card" section of the manual (page 150). If you need a manual, you can download one from the manufacturer's web site at
http://support.nikonusa.com/app/answers/detail/a_id/16763
Jul 16, 2011 • Cameras
1helpful
2answers
I want to delete multiple pictures on my camera, and also remove the date while taking pictures.
Delete Pictures (page 79 from User Manual)
Remove Date (also check page 77)
Hope this helps (remember to rate and comment this answer).
4helpful
How to delete pictures from my camera as i can't find my manual and i have not used it very often
If you want to delete selected pictures, follow below procedure:
Press Play button that is located under navigation buttons, see the picture in lcd that need to be deleted, press Delete button located it lower right corner, camera will ask confirmation, press OK by center button in navigation buttons to delete selected picture.
If you want to delete all pictures at once, go to Menu and select Format option to delete all pictures/ video clips etc in memory card.
Click Sony Support to download DSC-S730 camera user manual and check page-15 for details.
Thanks.
3answers
Click Sony Support to download instruction manual copy of NWZ-E438F that has info about deleting pictures.
1helpful
2answers
Disk says not enough space on disk to finilize?
Each time you execute finalization, the disc remaining space will decrease by approximately 13 MB. If you don’t have enough room, it won’t allow you to finalize the disc.
To finalize this disc, you have to delete some pictures to make enough space. But don’t worry, before you delete those pictures, you can save them to your computer.
Find out the CDs came with your camera, refer your manual page 51 - 61 to install ‘PIXELA PTP Manager’ , connect your camera and computer with USB cable, and copy some pictures to your computer, then delete the pictures on camera side. If still not enough room, copy more and delete more. make it enough to do the finalization.
1helpful
2answers
Dont no how to delete pictures from my album on my fone.
How do i delete all my album images on my t-mobile phone. (SGH-t319) samsung. please help asa.
Ella
Deleting pictures from cybershot viewer
Emmmeee,
I had the same problem with my digital cam/corder! An alternative solution to deleting pictures off the camera is, trickily enough, through your computer! This may be a bit of a hassle as you have preloaded your pics. What you will need to do is redownload your pics. You should be asked the option of deleting your pictures after download, and you click on the box.
4helpful
2answers
This is not working!how can i delete pictures form my cyber shot viewer?
4helpful
Deleting multiple pictures at once from Camera itself
go to view pictures. then click menu, there should be a delete option. then select what you want to delete. hope that helps
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
