Hi, its not the buttons with the numbers on you need to press from what io can remember its the following guide for most rover stereo's if you have any problems then post me a message back then ill assist you further ok
Switch on the Radio ('CODE' appears in the display). Press pre-set button 1.
Press one of the manual tuning buttons < or > to select the first digit of the security code. Press pre-set 1 to store the first digit in the unit's memory.
Use either tuning button to select the second digit of the code. Press pre-set 1 to store the second digit.
Select the third digit, again using the tuning buttons. Press pre-set 1 to store third digit to memory.
Select the final digit (the display will now show the full four digit code). Press pre-set 1 to store the final digit.
If the correct code has been selected, a two-tone bleep will sound and the radio will operate.
Each time you get it wrong the time delay before you can try again DOUBLE'S.
Hope this sort's your problem
