Check voltage to both coil and hall sender. should get battery voltage across two outer terminals on hall sender. battery voltage at black wire on coil. should get 5volts[pulsing] out put on center wire on hall sender. if input voltage ok but out put not, hall sender faulty. coil and fuel pump need an engine speed signal to activate.
do u have power to the ECM?
