Efficient Networks SpeedStream  5360 DSL/Cable Modem (SPEEDSTREAM5360) Logo
Posted on May 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intermittent DSL connection. Frequent need to reboot modem.
I have a Speedstream 5360 DSL modem with service through AT&T. Until recently, my DSL connection has been very reliable. For the last several weeks my DSL connection has been cutting out intermttently. The Windows 7 network troubleshooter identifies the problem as coming from the modem and recommends rebooting the modem. This usually works, however, the problem recurs and I need to reboot the modem every hour.
The modem always presents with the normal 3 green lights (power, DSL and enet) even when there is no internet connection. There should be no interference, since our wireless phones are DECT.
I have recheck all wired connections and even taken my wireless router (D-Link DIR-655) out of the loop -- connecting the modem directly to my PC -- but this has not helped.
Any suggestions? Is this 7 year-old modem giving up the ghost?
Anonymous
Level 2:
  • Expert 70 Answers
  • Posted on Jun 16, 2010
Anonymous
Expert
Level 2:
Answers
70
Questions
0
Helped
20175
Points
127
The modem is already old and obselete try to upgrade the modem. even though the lights on your modem works. try to call ATT because they can run a line test so they can determine if the connection is good or not
Could not get connection
It sounds like the phone line isn't hooked up or you have no service.
I need a driver i dont have one
need driver for speedstream 5360 dsl modem
3helpful
2answers
Buying a use modem
Siemens SpeedStream Modem (4100) (SS4100) is better
DSL connection (Modem) problem
Contact AT&T DSL support for help in getting your network to work. And do not believe them if they tell you your modem is no good. They want to shut down their DSL service and will go to any length, lying included, to get people to change over to their fiber optic system.
3helpful
Intermittent ADSL connection
The DSL light blinking or going out indicates that the DSL modem is loosing sync. This is usually caused by noise on the line. When you get the DSL service you should be given filters to put on all of your phones so that the phones will not interfere with the DSL signal. Those filters need to be attached to anything connected to the phone line that has the DSL on it except for the DSL modem. Other than that the problem could be on the service providers end, something outside your home, or the DSL modem going out. I would suggest that you verify everything is filtered, then contact your service provider so they can run test on your DSL line.
Modem cold to touch
hey hi,
frequent disconnectes suggest tat u might have an intermittent sync prob that might be due to,
1 )filter problem(filter is a small box ,it is also called as splitter that splits ur broad band connectivity and telephone line)
so try isolating the filter that isz
connect the cable runnin at the back of ur modem directly into ur wall jack.
this will probably solve the problem
2)next reason is , it might be a line issue pls cal ur broad band help desk they ll sort it out
ur modems temperature has nothing to do with this.
try this n let me know .
INSTALL A MODEM
The 5360 is techncially a bridge, not a modem, so it doesn't require software drivers for installation and operation.
There is a 5360 firmware upgrade, but it should only be used in certain situations -- see Related Articles at right for further information.
Note that DSL and cable bridges are often called "modems" because that is the familiar term for a device that connects the residential user to the ISP.
Please refer the link below:
http://kb.efficient.com/display/1/articleDirect/index.asp?aid=45459&r=0.9242823
Also refer the FAQ for 5360:
http://www.broadbandreports.com/faq/eff/6_5360
Thanks
Speedstream 5360 modem
  1. From the System area, , select Network Settings.
  2. Select Edit Settings.
  3. Select Additional Settings, and then select PPPoE Settings.
    1. Enter the PPPoE information provided by .........on the screens for: .......
    2. User Name ......
    • Password
    • Service Name
    1. Select Done. When prompted, select Test Xbox Live Connection.
    Top Efficient Networks Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
