Where to get spare part for the broken whisk. the whisk still can be used but for temporarily only. I can only used it for 2 or 3 times then the flexible wire bunch broken again.
First try adjusting it. The head may be set so low, the head can't latch. Does it latch with no whisk attachment? The video shows how to adjust it with the whisk in place using a dime..
If that isn't the reason, spares are available and dealer service is available.
this might help... the whisk has a slightly larger whole then the other attachments. it is also inset. there is a washer that holds the spring on. if that is slightly off or bent it won't sit in the Whisks inset right. look a little closer to that and the spring. if there happened to be dried on food that could be the slight difference that can prevent it from staying one. Hope this helps!!!
Hi from the Philippines and welcome to FixYa, I am Kelly
Is it just the power whisk or all attachments that do not rotate? On the A701A there is a clutch and spring fitted to the gearbox. (Spring loaded clutch) There is a pin in the cover that actuates the clutch. If the pin is broken or come out of the cover then the front of the machine will not work. (you may have to have someone fabricate a new pin!) If the clutch spring has broken you will experience the symptom you described also.
See http://www.smallappliance.com/product.asp?pid=5623&cur=USD&sid=18956&mid=5&gid=18978&prdCls=P&PartsPaNu=1&shopBy=Brand
(2 pages)
And you will find spare parts online for your braun which i believe is model nr 4642 (se baseplate).
You may also use braun's own spare parts finder at: http://www.service.braun.com/product/product.asp?rg=NA&c=US&l=GB&typ=pf&frmTyp=s&grp=0&s=4642&subgrp=&des=&sgrp=s&sString=4642'HH'HH06'H'MultiMix&seite=2
But you will have to contact one of the authorised service partners to buy.
Get the type number from the base plate and visit www.smallappliance.com for purchasing attachments. Or check out braun.com and use their spare parts finder.
I took a small crowbar, and put the curved end up inside the whisk, and hammered the other end lightly. After about 20 taps, the peg was lined up with the sideways opening so I could twist it off. When I got it off, it looked like there was either flour inside the part where the whisk attaches, or some light corrosion was going on. Either way, I'm going to put a little grease in there so it doesn't happen again.
I just took a look at the www.hobartcorp.com web site and found a lot of parts lists. I did't find the AE200, but there were several listings for A200. You can ask Hobart if the A200 and the AE200 are the same on the inside.
