Neff U1461 Double circotherm plus Electric Oven Logo
Posted on May 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My U1461 oven is taking a long time to heat up, what could this be?
Anonymous
Level 2:
Sergeant:
  • Expert 228 Answers
  • Posted on May 29, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
228
Questions
0
Helped
124285
Points
510
Check oven fan is starting and maintaing a steady speed these seize up with carbon very soon after useage.
2answers
tip
Common heating faults with Neff U1461 Double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
3helpful
OVEN DOES NOT HEAT IN FAN ASSISTED MODE but the fan works ok
I would suggest that the oven element is faulty
This is located at the rear of the innner oven compartment behind a removeable cover.
2helpful
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Please rate my solution.
Thanks.
Light on fan on no heat
Hi.
You need to fit a new oven element, as this is the reason you are getting no heat.
Thanks.
Trying to replace main oven bulb: cover jammed
Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
Neff model U1461
your convection element has blown by one online and replace it yourself
Manual for my oven
Go to the Neff site and dowload a manual
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
