TRANSMISSION DONT HAVE A DIP STICK.IT HAS A RED FILLER CAP INSTEAD.TO CHECK TRANSMISSION FLUID THE CAR HAS TO PUT ON A LIFT LEVEL.TRANSMISSION HAS A CHECK PLUG.ITS UNDER THE EXTENSION HOUSING.THE OIL PAN DRAIN PLUG IS BELOW IT.YOU NEED A DRAIN PAN AND THE CAR NEED TO BE RUNNING AT OPERATING TEMPERATURE.WITH ENGINE RUNNING YOU REMOVE THE CHECK PLUG.IF NO FLUID DIPS OUT YOU NEED TO ADD SOME FLUID.IT FLUID POURS OUT YOU HAVE TOO MUCH TRANSMISSION FLUID IN SYSTEM.IF YOU GET A SLOW DRIP YOU HAVE THE CORRECT AMOUNT OF FLUID IN TRANSMISSION.THE CAR HAS TO BE LEVEL AND YOU PUT FLUID IN THE TOP OF TRANSMISSION WHERE THE RED VENT FILL CAP IS.YOU NEED A LONG LONG FUNNEL TO PUT FLUID IN WITH OUT SPILLING FLUID ALL OVER THE PLACE.
SOURCE: Might have transmission fluid leak????
its fairly easy to be honest.you only need the tool to check transmision temp.it should be checked at a temp of 40 degrees c.so i reckon 10-15 mins from cold on idle(dont drive it ) should be about right.then remove the plug in the sump.this exposes a tube that goes in to the sump that is the right length so that only excess oil will drain out.Bassicaly the tube allows the sump to drain until the correct ammount of oil is in there.if you need to top up there is a short tube with a red cover over the top of it.remove this and top up until oil drains out the sump from the hole where the sump plug goes.go here for a picture that explains all.......
http://www.2carpros.com/forum/transmission-fluid-vt159056.html
SOURCE: When and How to check transmission fluid
if it is a manual transmission you have to check it from under the car by opening the fill plug. if fluid starts flowing out your full if not than you need to service it.
if it is an automatic it will be close to the firewall and hard to spot. but it is there. if you have 45,000 miles on it you should have the transmission serviced whether it is an automatic or manual.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: there is no dip stick to check the transmission
No there is not. There is on a fill hole for rebuild and fill purpose's.
SOURCE: Transmission fluid type and level
This is complicated.... Ok, your right, no dip stick is there! This is how it works.
Underneath the car, there is a plug (11mm) on the transmission case on the passenger side. It is about 3" up from the pan edge and on the front side of the case. With the engine running in PARK, remove this plug. If trans fuild doesn't run out of the hole, the level is low. Pour it in the hole on top (where the red cap is) until the fluid runs out - all while the car is running. Once it is roughly dribbling out, the trans is considered full. replace plug. Your done!!
Easy ehh? Dexron III fluid
SOURCE: I cannot find the dip stick to check the transmission fluid level on a Daewoo Nubira
TO CHECK TRANMISION OIL YOU NEED TO OPEN A PLUG AT THE LEFT AXEL AT THE TRANSMISION THE TOP PLUG TO VERIFIED LEVEL AND THE LOWER PLUG TO DRAIN TRANSMISION OIL.
Welcome to FIxYa.com
You have a dip stick to check it with. Start engine let it warm up to operating temp then pull dip stick wipe off end the dip it back in and pull it back out and read level on stick. Do not over fill. transmission fluid rises with heat
Regards, Lee Davidian
Thank you for using FixYa,com.
